SS-V: 5010 Z-Shaped Cantilever
Test No. VNL02Find vertical displacements of a Z-shaped cantilever beam under transverse loads of varying magnitude.
Definition
A Z-shaped cantilever is under action of a transverse load of max 4000 N (Figure 1).Figure 1.
The load is conservative and its direction does not change while the cantilever deforms.
The material properties are:
- Properties
- Value
- Modulus of Elasticity
- 2.e+11 pa
- Poisson's Ratio
- 0.3
Results
The following table contains values of vertical
displacement Uz for different loads in mm.
*SOL Reference is a thin shell model
1 A.A. Becker, Background
to Finite Element Analysis of Geometric Non-linearity Benchmarks, Published by
NAFEMS, Ref:-R0065, pg. 61 Page 66
