SS-V: 1150 Buckling
Test No. VS16 Find the critical compression load at which the cantilever beam buckles.
Definition
Dimensions: L = 1000 mm, b = 20 mm, h = 20 mm
Where,
            - b
 - Breadth of the rectangular section.
 - h
 - Height of the rectangular section.
The material properties are:
        - Properties
 - Value
 - Modulus of Elasticity
 - 2.1e11 pa
 - Poisson's Ratio
 - 0.3
Results
The following table summarizes
                the critical load.
| Reference KN* | SimSolid KN | |
| Critical Load | 6.90 | 6.908 |
*The reference result is calculated by:
                Where,
- Elastic modulus.
 - Area moment of inertia.
 - Length of the beam.
 - Effective length factor = 2 for cantilever beam.
1  James M. Gere, Mechanics of
                Materials, 6th Edition.
