SS-V: 1010 Twisted Cantilever Beam
Test No. VS02 Find tip deflections of a twisted cantilever beam when subjected to shear loads.
Definition
A cantilever beam, twisted by 90 degrees, is subjected to two different until loads at the
        free end (Figure 1):
      - in-plane shear
 - out of plane shear
Loads are uniformly distributed along the face.
The units are IPS.
The material properties are:
    - Properties
 - Value
 - Modulus of Elasticity
 - 29e+6 psi
 - Poisson's Ratio
 - 0.22
Results
The following table summarizes the tip displacements [in].
      | Theory (beam theory) | SimSolid | % Difference | |
| In-plane Shear (+Y direction) | 5.4240E-03 | 5.4540E-03 | 0.55% |
| Out-of-plane Shear (+ X direction) | 1.7540E-03 | 1.6291E-03 | -7.12% |
1  MacNeal, R.H., and
                        Harder, R.L., A Proposed Standard Set of Problems to Test Finite Element
                        Accuracy, Finite Elements in Analysis and Design, 1 (1985)
                3-20.
