SS-V: 1100 Raasch Challenge
Test No. VS11 Find the tip displacement at the free end of a thick, doubly curved beam.
Definition
The load is a uniform load 1.0 lbf out of plane.
The units are IPS.
The material properties are:
    - Properties
 - Value
 - Modulus of Elasticity
 - 3300 psi
 - Poisson's Ratio
 - 0.3
Results
The following table summarizes the
        tip displacement results [in].
| Theory | SimSolid | % Difference | |
| Tip displacement | 4.9355E+00 | 4.9314E+00 | -0.08% |
1  F.T. Wong, Testing of
        Shell Elements using Challenging Benchmark Problems.
