SS-V: 1020 Curved Beam
Test No. VS03 Find tip deflections of a curved beam when subjected to in-plane and out-of-plane loads.
Definition
A curved beam, spanning a 90 degree arc is fixed at one end and free at the other (Figure 1). The beam is subjected to
        two different loads at the free end (Figure 2):
      - in-plane load
 - out-of-plane load
The units are IPS.
The material properties are:
    - Properties
 - Value
 - Modulus of Elasticity
 - 1e+7 psi
 - Poisson's Ratio
 - 0.25
Results
The following table summarizes tip displacement (center face) in the direction of the load
          [in].
      | Theory (Curved beam theory) | SimSolid | % Difference | |
| In-plane Load (+Y direction) | 8.7340E-02 | 8.8554E-02 | 1.39% |
| Out-of-plane Load (+ Z direction) | 5.0220E-01 | 5.0542E-01 | 0.64% |
1  MacNeal, R.H., and
                        Harder, R.L., A Proposed Standard Set of Problems to Test Finite Element
                        Accuracy, Finite Elements in Analysis and Design, 1 (1985)
                3-20.
