Imported Pressure
Imported pressure allows you to bring in complex, non-uniform pressure distributions from other analysis software, typically Computational Fluid Dynamics (CFD) simulations.
This is useful for analyzing components subjected to pressure fields that vary across the surface, such as the aerodynamic pressure on an aircraft wing or the pressure on a car's body.
Apply Imported Pressure
Apply pressures from an external comma separated values (.csv) file. Available only for static analysis.
  1. In the Project Tree, open the Analysis Workbench Workbench.
  2. On the workbench toolbar, click Pressure → Imported Pressure.
    Imported Pressure dialog will open.
  3. Define units for coordinates and pressure
  4. Click Import from .csv. Browse to the desired .csv file in File Explorer and click Open.
  5. Information from the .csv file is posted at the bottom of Imported pressure dialog to review. Click OK to create and map the load at specified points./parts.
The .csv file contains one header row and one or more additional data rows.
Imported pressure .csv file format fields are as follows:
  • ID (optional) – Alphanumeric value used to identify a specific point.
  • X, Y and Z – Numeric values Spatial location used to map pressure to the nearest point on a face.
  • Pressure – Numerical value.
  • Part_ID (optional) – Numerical value. ID of the part to map the pressure. Mapping fails if the part with specified part ID is not present at the spatial location defined in X, Y and Z.
  • Part_Name (optional) - Alphanumeric value. Name of the part to map the pressure. Mapping fails if the part with specified part name is not present at the spatial location defined in X, Y and Z.
Note: If both Part ID and Part Name are defined, Part name takes precedence.
Example CSV File
ID,X,Y,Z,Pressure,Part_ID,Part_Name
1,216,417,40,100,15,square tube
2,216.975,417,40.0961,100,15,square tube
3,217.913,417,40.3806,100,15,square tube
