Set Default Input/Output Units
Specify a unit system for both input and output.
- In the main toolbar, click Settings > Default units.
- In the dialog, specify the Units system.
- Click the Input units tab.
- Use the drop-down menus to specify desired units.
- Click Output units tab.
- Use the drop-down menu to specify desired units.
Under Output format, select Scientific,
Engineering, or Concise mix
numerical output format.
Note:
With Engineering format, setting too few digits after the dot may result in zero quantity output values. For example, the number 0.0000056 specified with Engineering format and 3 digits after the dot will be displayed as 0.000. In most cases, Concise Mix is preferred.
Click OK.
Note: To change the units for a particular/existing project, in the Project Tree right-click on Units and click Update.
