Mouse Controls
Mouse controls for model view manipulation and component selection in SimSolid
Default Settings
The default SimSolid mouse buttons are mapped as follows:
| Mouse Control | Description |
| 3D-Rotate | Click + drag Left mouse button |
| Zoom | Mouse scroll wheel Note: When zooming in/out, this changes the
center of rotation/orbit. |
| 2D-Pan | Click + drag Right mouse button |
Modeling Window Controls
The following mouse controls are used within the modeling window:
| Select individual entity | Left mouse button |
| Select multiple entities | Control + Left mouse button |
| Display entity context menu | Right mouse button |
| Display global context menu | Right-click in empty area of modeling window |
Note: SimSolid supports
3Dconnexion's SpaceMouse and 3Dconnexion 3DxWare. Version 10.6.5 or newer is
required. These are not yet supported on virtual machines.
Change Mouse Control Settings
Modify mouse controls from the default settings.
- In the menu bar, click .
- In the dialog, use the drop-down menu to select desired mouse settings.
- Click OK.
