Configuration File
Used to manually activate or deactivate a set of features.
The basic syntax for the config file is as
follows:
<config>
<options>
<option name= “****” value="true/false" />
</options>
</config>The following options are supported.
- a. Pre-defining the solution settings
- The following is used to define the default solution
settings.
This code helps set default solution settings before initiating a SimSolid session.<solution_settings> <!-- Adaptation = 0 - Global; 1 - Global + local; 2 - Custom --> <setting name="adaptation" value="2" /> <!-- The rest of settings is for custom adaptation only --> <setting name="max_number_of_adaptive_solutions" value="3" /> <setting name="adapt_to_features" value="false" /> <setting name="adapt_to_thin_solids" value="false" /> <!-- Refinement level = 0 - standard; 1 - increased; 2 - high --> <setting name="refinement_level" value="0" /> </solution_settings> - b. Hide/show solution settings
- Solution settings can be hidden or shown in the Project Tree for each subcase using the following
source
code.
The following example shows default solutions settings for global + local, including the code to hide settings in the Project Tree.<option name="hide_solution_settings" value="false" /><config> <options> <option name="hide_solution_settings" value="true" /> </options> <solution_settings> <!-- Adaptation = 0 - Global; 1 - Global + local; 2 - Custom --> <setting name="adaptation" value="1" /> </solution_settings> </config>
Methods to Invoke config File
There are three methods to invoke the config file.
- 1. Environmental variable
- Set up the environment variable as shown
below:
Once the variable is set and saved, open a new SimSolid session to notice the influence of the config file.Variable name : SIMSOLID_CONFIG_PATH Variable value : <file path> - 2. Command line
- The respective config file can be patched to the
SimSolid session with the following
line:
<Path to SimSolid installation folder>\simsolid.exe> --config <Path to SimSolid configuration file>\simsolid.config - 3. Place the config file in the installation directory
- The config file with desired settings must be saved and can be placed in the SimSolid installation folder. Once a new session is opened, the settings in the config file will be reflected.
