Comparison of functions available in SimSolid , SimSolid Standard, SimSolid Advanced, and
and Inspire.
Note: The trial version/edition supports all functions supported by the Standard
edition of SimSolid.
Capacity
Table 1.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Limits on assembly face facets |
No limits |
No limits |
500k facets |
500k facets |
No limits |
| Limits on parts in the CAD assembly |
No limits |
No limits |
250 parts |
250 parts |
No limits |
Simulation Types
Table 2.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Structural linear |
Yes |
Yes |
Yes |
Yes |
Yes |
| Contact non-linear |
Yes |
Yes |
Yes |
Yes |
Yes |
| Material non-linear |
Yes |
Yes |
No |
No |
No |
| Geometric non-linear |
Yes |
Yes |
Yes |
Yes |
No |
| Incremental geometric non-linear |
No |
Yes |
No |
No |
No |
| Temperature-dependent structural |
Yes |
Yes |
No |
No |
No |
| Linear buckling |
No |
Yes |
No |
No |
Yes |
| Structural sequential |
No |
Yes |
No |
No |
Yes
(Partial) |
| Structural thermal |
Yes |
Yes |
Yes |
Yes |
No |
| Multi-loadcases |
Yes |
Yes |
No |
No |
No |
| Structural superelement export |
Yes |
Yes |
No |
No |
No |
| Thermal steady state |
Yes |
Yes |
Yes |
Yes |
No |
| Thermal transient |
No |
Yes |
No |
No |
No |
| Non-linear thermal steady state |
Yes |
Yes |
No |
No |
No |
| Non-linear thermal transient |
No |
Yes |
No |
No |
No |
| Thermal imported |
Yes |
Yes |
No |
No |
No |
| Modal |
Yes |
Yes |
Yes |
Yes |
Yes |
| Modal prestress |
No |
Yes |
No |
No |
Yes |
| Modal superelement export |
Yes |
Yes |
No |
No |
No |
| Modal rotordynamics |
No |
Yes |
No |
No |
No |
| Linear dynamics (time, frequency, random response,
spectrum) |
Yes |
Yes |
No |
No |
No |
| Frequency multi-loadcases |
No |
Yes |
No |
No |
No |
| Squeak and rattle |
No |
Yes |
No |
No |
No |
| Fatigue |
No |
Yes |
No |
No |
No |
| Structural superposition |
Yes |
Yes |
No |
No |
No |
| Structural envelope |
Yes |
Yes |
No |
No |
No |
| Thermal superposition |
Yes |
Yes |
No |
No |
No |
| Electromagnetics |
No |
Yes |
No |
No |
No |
Geometry Sources
Table 3.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Autodesk Fusion 360 direct integration |
Yes |
Yes |
No |
No |
No |
| Onshape direct integration |
Yes |
Yes |
No |
Yes |
No |
| Siemens NX direct integration |
Yes |
Yes |
No |
No |
No |
| Inspire direct
integration |
Yes |
Yes |
No |
No |
No |
| SimLab direct integration |
Yes |
Yes |
No |
No |
No |
| STL files |
Yes |
Yes |
No |
No |
Yes |
| ACIS files |
Yes |
Yes |
Yes |
No |
Yes |
| CATIA (V4, V5, V6) files |
Yes |
Yes |
Yes |
No |
Yes |
| CGR files |
Yes |
Yes |
Yes |
No |
Yes |
| Inventor files |
Yes |
Yes |
Yes |
No |
Yes |
| JT files |
Yes |
Yes |
Yes |
No |
Yes |
| NX files |
Yes |
Yes |
Yes |
No |
Yes |
| Parasolid files |
Yes |
Yes |
Yes |
No |
Yes |
| PTC/Creo files |
Yes |
Yes |
Yes |
No |
Yes |
| SolidWorks files |
Yes |
Yes |
Yes |
No |
Yes |
| STEP files |
Yes |
Yes |
Yes |
No |
Yes |
Material Properties
Table 4.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Isotropic |
Yes |
Yes |
Yes |
Yes |
Yes |
| Orthotropic |
Yes |
Yes |
No |
No |
No |
| Rigid |
Yes |
Yes |
Yes |
Yes |
No |
| Non-linear table driven stress- strain curves |
Yes |
Yes |
No |
No |
No |
Assembly
Table 5.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Inflated skins |
Yes |
Yes |
No |
No |
Yes
(Extrude) |
| Composites |
Yes |
Yes |
No |
No |
No |
| Liquid Body |
Yes |
Yes |
No |
No |
No |
| Gas Body |
Yes |
Yes |
No |
No |
No |
Connections
Table 6.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Bonded |
Yes |
Yes |
Yes |
Yes |
Yes |
| Sliding |
Yes |
Yes |
Yes |
Yes |
Yes |
| Separating contact with friction |
Yes |
Yes |
Yes |
Yes |
Yes |
| Bolted |
Yes |
Yes |
Yes |
Yes |
Yes |
| Virtual connectors |
Yes |
Yes |
No |
No |
Yes
(Partial) |
| Spot welds |
Yes |
Yes |
Yes |
Yes |
Yes |
| Laser welds |
Yes |
Yes |
No |
No |
No |
| Fillet/seam welds |
Yes |
Yes |
Yes |
Yes |
Yes |
| Adhesives |
Yes |
Yes |
No |
No |
No |
| Align |
Yes |
Yes |
No |
No |
No |
| Clamping |
Yes |
Yes |
No |
No |
No |
Boundary Conditions
Table 7.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Immovable constraint |
Yes |
Yes |
Yes |
Yes |
Yes |
| Sliding constraint |
Yes |
Yes |
Yes |
Yes |
Yes |
| Hinge constraint |
Yes |
Yes |
Yes |
Yes |
Yes |
| Spring support (elastic foundation) |
Yes |
Yes |
Yes |
Yes |
No |
| Grounded bushing support |
Yes |
Yes |
No |
No |
Yes |
| Cable/ Rod |
Yes |
Yes |
No |
No |
No |
| Spring |
Yes |
Yes |
No |
No |
No |
| Shock Absorber |
Yes |
Yes |
No |
No |
No |
| Prescribed displacements |
Yes |
Yes |
Yes |
Yes |
Yes |
| Alignment |
Yes |
Yes |
No |
No |
No |
| Pressure |
Yes |
Yes |
Yes |
Yes |
Yes |
| Force |
Yes |
Yes |
Yes |
Yes |
Yes |
| Gravity |
Yes |
Yes |
Yes |
Yes |
Yes |
| Temperature |
Yes |
Yes |
Yes |
Yes |
No |
| Heat flux |
Yes |
Yes |
Yes |
Yes |
No |
| Convection |
Yes |
Yes |
Yes |
Yes |
No |
| Volumetric heat |
Yes |
Yes |
Yes |
Yes |
No |
| Solar Load |
Yes |
Yes |
No |
No |
No |
| Remote Force/moment |
Yes |
Yes |
Yes |
Yes |
Yes |
| Bearing load |
Yes |
Yes |
Yes |
Yes |
No |
| Bolt/nut preload |
Yes |
Yes |
Yes |
Yes |
Yes |
| Hydrostatic load |
Yes |
Yes |
Yes |
Yes |
No |
| Wind Load |
Yes |
Yes |
No |
No |
No |
| Translational Inertia load |
Yes |
Yes |
Yes |
Yes |
Yes |
| Rotational Inertia load |
Yes |
Yes |
Yes |
Yes |
Yes |
| Distributed mass |
Yes |
Yes |
Yes |
Yes |
No |
| Inertia relief |
Yes |
Yes |
Yes |
Yes |
Yes |
| Static Loads imported from CSV |
Yes |
Yes |
No |
No |
No |
| Dynamic loads imported from CSV |
Yes |
Yes |
No |
No |
No |
| Thermal loads imported from CSV |
Yes |
Yes |
No |
No |
No |
| Table driven dynamic loads |
Yes |
Yes |
No |
No |
No |
| Dynamic base excitation |
Yes |
Yes |
No |
No |
No |
Results Output
Table 8.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Contour plots |
Yes |
Yes |
Yes |
Yes |
Yes |
| Animation (static and modal) |
Yes |
Yes |
Yes |
Yes |
Yes |
| Max/min locations |
Yes |
Yes |
Yes |
Yes |
Yes |
| Point value probes |
Yes |
Yes |
Yes |
Yes |
Yes |
| XY plots |
Yes |
Yes |
No |
No |
No |
| Reaction/contact forces |
Yes |
Yes |
Yes |
Yes |
Yes |
| Safety factors |
Yes |
Yes |
Yes |
Yes |
Yes |
| Frequencies and mode shapes |
Yes |
Yes |
Yes |
Yes |
Yes |
| Bolt/nut resultant forces |
Yes |
Yes |
Yes |
Yes |
Yes |
| Bolt internal forces |
Yes |
Yes |
No |
No |
No |
| Rivet forces |
Yes |
Yes |
No |
No |
No |
| Spot/seam weld resultant forces |
Yes |
Yes |
Yes |
Yes |
Yes |
| Contact response |
Yes |
Yes |
No |
No |
No |
User Productivity
Table 9.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Bookmark browser |
Yes |
Yes |
No |
No |
Yes |
| Save animation (as .mp4 files) |
Yes |
Yes |
No |
No |
Yes |
| Save images (as .png files) |
Yes |
Yes |
No |
No |
Yes |
| Units manager |
Yes |
Yes |
Yes |
Yes |
Yes |
| Default materials |
Yes |
Yes |
No |
No |
Yes |
| Standard views |
Yes |
Yes |
Yes |
Yes |
Yes |
| User defined views |
Yes |
Yes |
No |
No |
Yes |
| Measurement tool |
Yes |
Yes |
No |
No |
Yes |
| Spot regions for custom load application |
Yes |
Yes |
Yes |
Yes |
Yes |
Command Line Execution
Table 10.
Desktop |
Cloud |
Inspire |
Standard |
Advanced |
Altair One |
Onshape |
| Installation |
Yes |
Yes |
N/A |
N/A |
Yes |
| Invocation |
Yes |
Yes |
N/A |
N/A |
Yes |
| Batch mode |
No |
Yes |
No |
No |
Yes |
