Minimum Hardware Requirements
Learn the minimum requirements for supported platforms.
Supported Platforms
SimSolid supports Windows and Linux. The Linux version of
SimSolid works without any user-interface and is
meant to run jobs on HPC clusters.
Note: On October 14, 2025, Microsoft Windows 10
reached its end of support. Following Microsoft's messaging, all Altair 2026.0 applications no longer support Windows 10.
Altair is providing this information to help our
customers accommodate this change. Altair 2026.0
supports the Windows 11 operating system, along with our other Linux-based
operating systems. Please contact your local Altair
support team if you have any questions or concerns.
Windows
- Operating System
- Windows 11 (64-bit) on Intel i7 based computer or higher
- Memory
- At least 4 cores and 16 GB of RAM
- Graphics Hardware
- OpenGL graphics card, version 3.3 or higher
- Only dedicated AMD, Intel® Arc™, and NVIDIA graphics cards are supported (integrated onboard Intel chipsets are not supported)
- Hardware Settings
- The following options are available:
- Change the number of cores/processors used by the analysis solver. By default, the application detects and uses all available cores/processors during the computation to maximize the performance. The number of cores used can be decreased, if desired, to reserve some cores for other computer processes.
- Check the Use scratch files checkbox to use scratch files when running an analysis. Scratch files are written to a user-defined location, with the default location being the Temp directory. This functionality is useful for large assemblies with several million degrees-of-freedom as this helps reduce memory usage.
- Clear all entries in the Windows registry related to the application, such as material database location, and so on.
Linux
- Operating System
- Red Hat Enterprise Linux 9.4 (64-bit)
- CIQ Rocky Linux 9.4 (64-bit)Important: Linux users must have OpenSSL 3.0 or later installed, as the OpenSSL libraries have been removed from our packaging. For more information, please see this notice on Altair Community.
- Memory
