User Interface
Visual guide for navigating the SimSolid user interface.
Main Menu ToolbarProject TreeWorkbench ToolbarModeling WindowBookmark BrowserLegend
  1. Main Menu Toolbar - The main menu is used to access the most commonly used tools.
  2. Project Tree - The Project Tree is used to manage individual model entities. The main branches of the Project Tree are called workbenches. Each design study will have one Assembly workbench and one Connections workbench with definitions that apply to all design study analyses. A design study can have any number of analyses.
  3. Workbench Toolbar - Each workbench has a corresponding vertical workbench toolbar. Select a workbench in the Project Tree to display the corresponding workbench toolbar.
  4. Modeling Window - The modeling window displays the project geometry and gives you another method for manipulating entities. A list of mouse controls available in the modeling window can be found in the Mouse Controls section.
  5. Bookmark Browser - The Bookmark Browser is a convenient way to record your simulation modeling and results images. You can associate captions with images and export the entire gallery as image or animation files. If you click on a thumbnail in the browser area, you can return the modeling window to the state recorded in the thumbnail.
  6. Legend - The Legend displays contour plot data for a chosen analysis result. After running an analysis, you can select the results to display from the Analysis Workbench toolbar.
Main Menu Layout
Figure 1 shows a labeled map of the tools on the main menu.
Tip: Click on images for full-screen view.
Workbench Toolbars Layout
Figure 2, Figure 3, and Figure 4 show labeled maps of the tools on the workbench toolbars. The toolbar displayed is based on the currently selected workbench in the Project Tree.
Assembly Toolbar
Connections Toolbar
Figure 3.
Structural Analysis Toolbar
Figure 4.
Structural Superelement Export Analysis Toolbar
Figure 5.
Modal Analysis Toolbar
Figure 6.
Modal Superelement Export Analysis Toolbar
Figure 7.
Structural Dynamic Analysis Toolbar
Figure 8.
Squeak and Rattle Analysis Toolbar
Figure 9.
Thermal Analysis Toolbar
Figure 10.
Fatigue Analysis Toolbar
Electromagnetic S-Parameters Analysis toolbar
Modal electromagnetics analysis toolbar
