Element Quality definitions: WEDGE
WEDGE element types
The quality measures supported for WEDGE element types are as follows,
  1. Aspect Ratio
  2. Warpage
  3. Interior Angle
  4. Skew
  5. Volume
  6. Edge Length
  7. Stable time increment
  8. Mid node alignment ratio
  9. Mid node deviation ratio
Aspect Ratio
Aspect ratio of a WEDGE element is defined as the ratio of its longest edge to its shortest edge.
Warp Angle
The face warpage of a WEDGE element is defined as the maximum warpage among the three quadrilateral faces, each treated as a QUAD element.
Interior Angle
It is angle between the edges of a triangular/rectangular face of wedge. Minimum and maximum value of interior angle for each wedge element is calculated by considering all the faces of the wedge element.
Skew
The skew angle of a WEDGE element is defined as the maximum skew angle among its three quadrilateral faces and two triangular faces. Each quadrilateral face is treated as a QUAD element and each triangular face as a TRI element.
Volume
Volume of the WEDGE element.
Edge Length
Length of Wedge Edges.
The Stable time step is the time needed for a shock wave (stress / pressure wave) to cross the smallest distance in an element. It is used to determine the initial minimum time step required for explicit dynamic analysis. This parameter also depends on the material properties assigned to the elements apart from the element dimensions.
It describes how close a mid node can be displaced towards corner node along element edge.
It describes how far a mid node is displaced from the line joining corner nodes.
