Folds
Cracks
This option is used to identify crack elements present in the given body.
Crack elements lesser than this angle will be highlighted.
Within faceThis option will highlight the cracks present within the face only.
Include point crackBy default cracks along the Element Edge will be found. This toggle helps to also find cracks at a point (node).
Group connected elementsThis option will group the failed elements based on connectivity and create groups.
Auto Clean CracksThis option is used to cleanup predefined crack patterns.
ExampleCracks have been displayed for an angle of 20.
Wedges
This option is used to identify wedge elements present in the given body.
Wedge elements lesser than this angle will be highlighted.
Within faceThis option will highlight the wedges present within the face only.
Include point wedgeBy default wedges along the element edge will be found. This toggle helps to also find wedges at a point (node).
ExampleWedges have been displayed for an angle of 20.
