Disconnect
Dialog Box
This tool is used to separate a body that contains many topologically connected regions into individual bodies. By default, bodies are disconnected based on topology. However, by selecting Break at non-manifold edges, you can disconnect bodies at non-manifold edges.
- With Break at non-manifold edges toggle OFF
- With Break at non-manifold edges toggle ON
