Transfer Bodies
Dialog Box
Transfer Body is used to transfer bodies from one model to another model or another sub model. Selected bodies can have shared nodes between them.
- Bodies to Transfer
Select the input or source bodies from a model to transfer to the destination model/sub model.
- Destination model/sub model
Select a destination model or sub model. To select, click on this line edit and select a model or sub model from Assembly Browser.
- Preserve destination ID
Node, Element and Entity ID of the destination model or source model can be preserved by using this option.
Example 1 - Move bodies to Root of another model
From model "Sample_2.gda", the body named "body" is moved to the root of the model "Sample_1.gda".
- Before Transfer Body
- After Transfer Body
After Transfer Body
Example 2 - Move bodies to sub model of another model
From model "Sample_2.gda", the body named "handle", "handle_hold" and "handle_knob" are moved to the sub model "Base" of the model "Sample_1.gda".
After Transfer Body
