Scripting: Script Log Folder
Script Log Folder
This option lets the user choose the location to write the script log file. The default option is "Set to Script Log Folder".
Set to Script Folder
This option creates the log file (PythonScriptName_LogFile.txt) under the script folder.
Set to Selected Folder
This option allows the user to set the directory where the log file should be saved.
