Generate Results and Reports
The Aerospace menu provides you with access to various aerospace tools.
The NVH menu provides you with access to various NVH utilities.
Use the Safety ribbon to access crash and safety post-processing tools.
The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
The Vehicle Safety Tools preference file contains templates to plot IIHS front intrusion and IIHS side structure intrusion plots for Radioss and LS-DYNA files.
The MPDB tool offers a complete automated post processing solution of the MPDB Frontal Compatibility Assessment load case, for Radioss and LS-DYNA output files. It also has the capability to do the MPDB compatibility assessment for physical test data (scanned data) written out in STL format.
The Compare Time History diagnostic tool consists of two pages. On the first page, the input data files, such as plot, result, and FE files, are selected. Page two contains the data needed to compare the reference files and comparison files.
Allows you to transform vector results from a time history or animation result files according to a coordinate system defined by three nodes from the same result file.
The Pedestrian Impact tool facilitates the post-processing of pedestrian analysis.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
