Calculate the OLC and Modifier
  1. From the MPDB Projection Tool dialog, verify that the OLC & Modifier Calculation option is checked.
    Note: This option is activated by default.
  2. Select a file type from the drop-down menu.
    • T01 (Radioss file)
    • Binout/Nodout (LS-Dyna)
  3. Use the file browser to select the requested output file.
  4. Enter the requested input to extract the barrier acceleration value requested for the OLC and Modifier calculation.
  5. Activate the Filtering check box and choose the filter options to apply on the time history outputs.
