Select a Projection Rule
                From the Plot tools, click the Tensor tool.
                From the Tensor panel, click the Projection Rule
                    button.
                The Projection Rule dialog is displayed.
                Select the primary and secondary axes from either the global or user-defined
                    system (selected for Resolved in).
                When the primary axis is perpendicular to the shell plane, the secondary axis is used.See the Projection Rule topic for additional information.
