Manage the Legend Display
                From the Plot tools, click the Tensor tool.
                From the Tensor panel, under Legend threshold, activate the
                        Max check box and enter the value to be assigned to
                    the highest color in the contour plot.
                The new value is also changed in the Values section of the Edit Legend dialog.Note: If a value entered for threshold Max is invalid, it will not be applied and the panel will be updated to reflect the actual state.
                Activate the Min check box and enter the value to be
                    assigned to the lowest color in the contour plot.
                The new value is also changed in the Values section of the Edit Legend dialog.Note: If a value entered for threshold Min is invalid, it will not be applied and the panel will be updated to reflect the actual state.
 - For Multiplier, enter the multiplier for scaling all the result values.
                Click the Edit Legend button.
                Opens the Edit Legend dialog, where you can change legend properties.
