Computed Results
A listing of results that are computed in HyperView.
- Principal Stress and Principal Strain
 - For a given stress/strain tensor S, the three principals are obtained as the roots of the cubic equation below:
 - vonMises Stress
 - vonMises Strain
 - Signed vonMises
 - The sign of the signed vonMises is determined by the sign of that principal which has the biggest absolute value.
 - Pressure
 - The pressure is generated by the average of the 3 normal stresses:
 - Intensity
 - The absolute difference between Major and Minor stresses:
 - Max Shear
 - The maximum shear stress/strain:
 - Tresca
 - Computed as the Maximum of the following:
 - Lodeparam xi
[(27/2) *(P1+pressure) * (P2+pressure) * (P3+pressure)] / (vonMises* vonMises * vonMises); - Lodeparam theta
1 – [(2/Pi) * arccos(lodeparamxi)]; - Triaxiality
-pressure/VonMises - Extreme Principal (known as Absolute Max Principal in version 2024.1 or earlier)
 - The extreme of the three principal stresses (or strains).
In other words, it is the absolute maximum of the three principal stresses or strains, while preserving the sign.
 - Max Abs Principal
 - The absolute maximum of the three principal stresses or strains.
 - In-Plane P1/P2
 - These are valid only for 2D shell elements and are available in elemental system only. P1 and P2 is calculated after setting the ZZ, YZ, and XZ components of the base tensor to zero.
References
VonMises Strain Calculation - PapersYu Yang, Wang Ningfei, ZhangPing, Three-dimensional Damage Analysis of Free Loading Solid Propellant Grains Subjected to Low Temperature Loading. School of Mechano-Electronics Engineering, Beijing Institute of Technology, Beijing 100081, China.
 are in the “Tensor shear Strain” format. Various solvers
            output shear strains in one of the two formats: “Engineering shear strain” and “Tensor
            shear strain”. “Engineering shear strain” is twice that of “Tensor shear strain”. All
            solver data that has shear strains in “Engineering shear strain” are converted to
            “Tensor shear strain” before calculating the principals. This includes some solutions
            from
 represent the principal stresses as calculated above for a
            stress tensor.
 is the Poisson ratio set to a default value of
