Roll, Tread Width, Tread Change, and Track Width
Request Number: 80000040
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Roll Angle | deg | The suspension roll angle and is defined as the arctan of the difference in
wheel center displacements divided by the difference in wheel center y coordinates
or: atan((rdisp-ldisp)/abs(rwcy-lwcy) The sign is positive when the right wheel is in jounce and the left wheel is in rebound as in a left turn. |
| F3 | RESULT(3) | Tread Width | mm | The distance between the left and right tire patch points. |
| F4 | RESULT(4) | Tread Change | mm/m | The change in tread width due to a change in wheel displacement and is defined:
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Track Width | mm | The difference in wheel center y coordinates. |
| F7 | RESULT(7) | Not Used | Not Used | Not Used |
| F8 | RESULT(8) | Not Used | Not Used | Not Used |
