The solver expression that is to be computed at each analysis time step to find
its maximum value.
Factor
A value by which the maximum value of the Response Expression will be
multiplied to get MaxVal response.
Turn ON the Use plot check box in order to monitor and plot this
response during an optimization run.
In the above example, the response variable computes the maximum value of an expression
which is the absolute relative translational acceleration (Z-component) of a marker with
respect to another.
A user subroutine can be used by turning ON the User-defined check
box (see below).Figure 2. Response Type – MaxVal (User-defined)
Input
Function Name
The string which the solver input deck will use to invoke the user
subroutine.
Local File
Use this button to select a python file containing the function.
