Remove a Response Variable
                To delete a Response Variable, select the desired RV from the list and click
                    the Delete button.
Tip: Responses can also be deleted outside the wizard by
                        right-clicking on the RV in the Model Browser and
                        choosing .
                Such RVs will be highlighted in ‘red’ in the wizard and
                            will not be considered for the optimization study.Figure 2.
