The solver expression that is to be computed at each analysis time step to find
its minimum value.
Factor
A value by which the minimum value of the Response Expression will be
multiplied to get MinVal response.
Turn ON the Use plot check box in order to monitor and plot this
response during an optimization run.
In the above example, the response variable computes the minimum value of an expression
which is the absolute relative translational displacement (Z-component) of a marker with
respect to another.
A user subroutine can be used by turning the ON User-defined check
box (see below).Figure 2. Response Type – MinVal (User-defined)
Input
Function Name
The string which the solver input deck will use to invoke the user
subroutine.
Local File
Use this button to select a python file containing the function.
