Opening Model Files
From the File menu select
Or
From the Home tools, Files tool group, click the Open Model tool.Figure 1. -
From the Open Model dialog, locate and select the mdl file
to be loaded and click Open.
The model is loaded into the current MotionView window.
Tip: You can also drag and drop the mdl file directly into MotionView.
