User Defined Keywords
                From the MotionView browser, select a Signal
                    dimension data set in the Altair Driver Analysis.
The panel is displayed. -
                Expand the table by clicking on “…”, located under Value.
                Use entry 26 to 30 to define signal key and dimensions.
Figure 3.
Name Key Solver Variable ID ID of the solver variable of interest. Mass dimension Length dimension
Time dimension
Force dimension
Angle dimension
Exponents of the dimensions of the signal. Example:
Drive Torque has dimensions F1 L1
Expected entries:
Mass dimension: 0
Length dimension: 1
Time dimension: 0
Force dimension: 1
Angle dimension: 0
