General
The General option in the tree browser provides basic details and displays the entire model in the Help section. It is necessary for all the property files.
- Interpolation Scheme
- Defines the type of interpolation that is needed for the leaf profile.
- Data Shape Condition
- The Leaf Spring Builder builds leaf springs from two different kinds of
profile inputs or shape conditions.
- Free Shape Condition: In Free Shape
condition, an assembled leaf pack is generated. The leaf spring is
created with the center bolt represented as a fixed joint. The input
profiles of the leaves for this option will be the profiles as in a
leaf stack.Note: The leaf pack is assembled in the pack but is NOT installed in a vehicle, in other words, it is not deformed by the vehicle weight.
- Pre-Assembly: In Pre-assembly, you have individual leaf profiles for each leaf. These individual leaf profiles can be bolted together with the assembling load. The following image shows how the data of leaves are collected. If the free shape data of each leaf is available, it is preferable to create the leaf pack using this option.
- Design Assembly: In Design Assembly, an assembled and loaded leaf spring pack is generated. You have an assembled leaf spring pack installed in the vehicle with the actual vehicle loads on it. The leaf spring will be generated with bolt (Fixed Joint) and design load stored in the beam elements. The input profiles for this option will be the leave profiles extracted from a bolted and loaded leaf stack. See Assembled and Loaded Leaf Spring for additional information.
leaf stack.
Shape Measurements
The Leaf Spring Builder creates MotionView MDL leaf spring models which are only as good as the leaf shapes input entered in the software. Therefore, accurately measuring the leaf shapes in the required coordinate system is important. The coordinate system, its origin and orientation need to follow certain rules to be useful in creating a leaf-spring from the Leaf Spring Builder.The following sections describe the coordinate systems and measurement methods for the Free and Pre-Assembly shape conditions.
The coordinate systems and measurement methods for Design and Free are the same as discussed below.
- Measuring a Leaf Spring in Free Shape
- In Free Shape, the leaves are already assembled into a pack, but not installed in the vehicle. All of the leaves together form a single unit. In this condition, the measurements need to be made in a consistent coordinate system only. Also, it is necessary to input a correct Leaf Reference Location under the Axle tab. The Leaf Reference Marker will be created at this location.
- Unacceptable Selections:
Measuring a Leaf Spring in Pre-Assembly Shape
Leaves in the Pre-Assembly Shape condition are measured as independent entities. A common coordinate system needs to be chosen for all the leaves. The Leaf Builder takes an additional input called Bolt Location in the Pre-Assembly Shape condition, which is used to line up the leaves along a common vertical axis before they are bolted together in a MotionSolve simulation to create the assembled leaf pack.The following set of illustrations show acceptable and unacceptable selections
of coordinate systems, its origins and orientations of leaf shapes.
- Acceptable Selections:
- The bolt hole axis of each leaf must be parallel to every other leaf and to the Z-axis. The vertical locations of each leaf will be offset by MotionSolve during assembly, such that there is no contact between leaves.
- Unacceptable Selection:
The Leaf Reference Marker (henceforth referred to as LRM in this section) is the coordinate system in which all the points of the leaf profiles are created in MotionView. To move/orient a leaf spring, you can simply move and/or reorient the LRM.It is
necessary during measurement to have all the leaves positioned such that the
tangents at the leaf centers (clamped portion of the leaves) are parallel. A visual
inspection of leaf positions on the measuring table is done to ensure this is
generally sufficient to get a good leaf spring out of the Leaf Builder.
The Leaf Reference Marker is created at one of the following locations
based on shape condition:
- Free Shape: Leaf Reference Location as input by the user, Top leaf center for Underslung spring and Bottom leaf center for Overslung spring.
- Pre-Assembly Shape: Top leaf bolt location for Underslung spring and Bottom leaf bolt location for Overslung spring.
The Leaf Builder uses the Leaf Reference Marker-origin (location) as the point where the Axle is attached.
General Inputs for Leaf Property File (*lpf)
In the General Inputs block of a Leaf Property file, the attribute, type, and valid
value to be entered in TiemOrbit file format are detailed in the following table.
This table also provides information about the mandatory requirements for
attributes. An example of how a General Inputs block is represented in a TiemOrbit
file format is shown
below:
$---------------------------------------GENERAL_INPUTS
[GENERAL_INPUTS]
CURVEFITTING = 'LINEAR'
DIRECTORY = 'C:\USERS\NG\DESKTOP'
DISPMSOLVEWINDOW = 'TRUE'
NOOFLEAVES = 4.0
NOOFREBOUNDCLIP = 0.0
OUTPUTFILELABEL = 'TEST_LEAF_1'
SHAPECONDITION = 'DESIGN'
Attributes | Type | Valid Value | Required |
Directory | String | Directory path | Yes |
noOfLeaves | Integer | 1, 2, 3... | Yes |
curveFitting | String | Linear Quadratic Cubic |
Yes |
noOfReboundclip | Integer | 1, 2, 3... If there are none, then “ZERO” has to be mentioned. |
Yes |
shapeCondition | String | 'FREE' 'PRE_ASSEMBLY' |
Yes |
outputFileLabel | String | File_label | Yes |
dispMsolveWindow | String | 'TRUE, 'FALSE'' | Yes |
Units
Units are required for all types of the data files to be read by the builder. It
specifies the length, mass, force, angle, and time units employed in the file.
Currently, you will have to use the default units and have no control over
units.
Units for Leaf Property File (*lpf)
In the units block of Leaf Property file, the dimension, options, and conversion
factors to be used are detailed in the following table. An example of how a Units
block is represented in a TiemOrbit file format is shown
below.
$---------------------------------------------------------UNITS
[UNITS]
(BASE)
{LENGTH FORCE ANGLE MASS TIME}
MILLIMETER NEWTON RADIAN KILOGRAM SECOND
