2026
Controllers form the core of the driver. The Controller Library has various basic controllers its arsenal to calculate different driver outputs.
Closed-loop controllers use vehicle responses (for example, speed, position, yaw rate, etc.) as feedback to determine the vehicle inputs needed to match a desired vehicle response, such as following a demand lean profile (for two wheelers) or a path.
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
This section describes how to add a full vehicle model with the Altair Driver and include the events. The events are simulation commands that enable the Altair Driver control to perform the vehicle maneuvers. A model with an event exports an Altair Driver File (.adf) and the MotionSolve (.xml) files to be simulated.
This section describes all of the full vehicle events currently supported with Altair Driver. It also describes all of the events and their parameters.
Various plots are reported in different vehicle events. The plots are selected based on metrics that are important for a given event.
The Altair Driver is a set of MotionView models and libraries that allows MotionView users to control and script vehicle events.
Open-loop controllers define vehicle inputs directly without feedback (for example, steering wheel angle vs. time).
The Feed-forward controller is the predictive controller of the Altair Driver. It predicts some of the states of the vehicle after look ahead time, or look ahead distance, and accordingly drives the throttle and brake signals to match the demand signal (for example, speed).
A Proportional-Integral-Derivative (PID) controller is a feedback controller that computes a vehicle input using the error, the integral of error, and the rate of change of error between a desired vehicle response and the actual vehicle response.
Driver can be loaded using the Model Wizard of MDLLIB when the Full Vehicle with Driver option is chosen. Driver has some special requirements to interface with the vehicle model. These requirements are resolved automatically if the vehicle model is built using the Full vehicle with advanced driver option in the Model Wizard in MDLLIB.
Driver uses the Altair Driver File (ADF) to access all the event parameters in the Solver.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
