Replace Geometry
Replace a part in your model with an alternative design.
- Open or create a model.
Right-click the part you'd like to replace and select Part
Replace, then do one of the following:
- To import a new part from a CAD file, select From file, and then select a file.
- To select an existing part in the current model, select From part, and then click a part.
Tip:
- If the geometry does not align or you have unexpected results, try turning off the Part Replacement: Auto Positioning option in the Preferences.
- When selecting a part from a CAD file, materials in the CAD file will not be read.
