Partition
Divide a solid part into design and non-design regions by selecting a hole, pocket, or face to offset.
  1. On the Geometry ribbon, select the Partition tool.
    Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:
    • Select at the lower right corner of the currently displayed tool.
    • Click and hold the currently displayed tool.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
    Holes and pockets are automatically selected and shown in red.
  2. Select faces to partition.
    Selected faces are shown in red.
  3. Click a selected (red) feature to execute the partition, or select Apply on the microdialog.
  4. Use the microdialog to edit the default offset value. You can edit the offsets for multiple partitions while in editing mode.
    • Use the Reverse Direction button to change the direction of the offset.
    • Change the Thickness and press Enter. If the thickness you entered is invalid, the text box is highlighted in red.
  5. Right-click to exit the tool.
Note:
  • If you apply a partition to a design space, it automatically creates a non-design space.
  • For solids, if you enter a thickness of zero, you will get a surface in a new part. For surfaces, if you enter a thickness of zero, those surfaces will be placed into a new part.
  • You can edit the Default Offset value in the Preferences.
  • Solids and surfaces can be partitioned.
Create or Assign Variables to Parametrize a Model
Create or assign variables to parametrize a model. Variables can be created from a tool or the tool’s microdialog where f(x) is present.
You can create or assign existing variables via the microdialog or in various tools and contexts.
Keyboard Shortcuts & Mouse Controls
To Do this
Select a feature Click
Deselect a feature Ctrl+click
Add to the selection Ctrl+click
Execute the partition Click a selected (red) feature to preview and edit it. Click again to partition it.
Accept the partition and exit Right-click in editing mode
Delete the partition Delete or Shift+click
Exit tool Right-click and mouse through the check mark to exit, or double-right-click.
