Face Curve
Extract isoparametric curves from a surface in the U or V direction. This is useful for creating trim curves that run along a surface but are not attached to it.
Note: This page is under construction...
Isoparametric curves can also be used to recreate a given surface with different parameterization. Extract several isoparms and use the Loft tool to create a surface through them. An isoparametric curve extracted from a surface can be used as a snappable location when you need to place an object on such a surface.
Note: Double-click the curve to edit.
  1. On the Geometry ribbon, select the Face Curve tool.
    Note: The tool may be hidden in a dropdown menu. To access the dropdown menu, you can do one of the following:
    • Click and hold the currently displayed tool (NURBS).
    • Select at the lower right corner of the currently displayed tool (NURBS).
    The guide panel appears.
  2. Click a NURBS surface.
  3. Press Shift to switch between U and V directions. A preview is shown as you move your mouse over the surface. Click to extract the isoparm.
  4. You can do the following:
    • To edit an isoparm, double-click the extracted isoparm.
    • To add a new isoparm, while holding down Alt, move the mouse over the surface and then click.
    • To change the location of an existing isoparm, click, and then change the value in the text box.
    • To delete an isoparm, select the curve, and press Delete.
  5. Right-click and mouse through the check mark to exit, or double-right-click.
