From Surface Intersection
Extract curves from the intersection of two surfaces.
                On the Geometry ribbon, select the From Surface
                        Intersection tool.
 Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select  at the lower right corner of the
                                currently displayed tool. at the lower right corner of the
- Click and hold the currently displayed tool.
 Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
- Select
                To combine all targets and newly created curves, in the
                    guide bar select Options
                     , then turn on Combine
                    Curves. , then turn on Combine
                    Curves.
                The Surface 1 button is active. Click the first
                    surface.
                Tip: To change the first surface, click Surface 1, and then click another surface.
                The Surface 2 button is active. Click the second
                    surface.
                Tip: To change the second surface, click Surface 2, and then click another surface.
                Select Apply  .
                A new curve is created from the intersection of the two surfaces. .
