- Rendering Process OverviewAn overview of the typical rendering process.
- Inspire System RequirementsA list of supported operating systems and minimum requirements for hardware and       memory.
- Manage Rendering AssetsThe Assets folder includes a default set of images, textures, materials, models, and         environments that are used for rendering. Custom user-created materials and environments are         also saved in the Assets folder, in the User subfolder. You can install the full Altair and continue to install updates when the online library is         updated.
- Interactive RenderingInteractive rendering modes are display modes that render your scene in real time, so     you can interactively apply materials, modify the environment, and change the camera     position.
- EditorsConfigure materials, the environment, lights, labels, the camera position, and the         rendering settings.
- LibrariesThe Render Library contains preset and saved custom materials, environments, and         models.
- RenderCreate a final rendered image. Learn how to adjust the rendering settings and change         rendering engines.
