A list of supported operating systems and minimum requirements for hardware and
      memory.
          - Operating System
          - Windows 10 (64-bit)
          - Windows 11 (64-bit)
Notice: As of October 14, 2025, Microsoft Windows 10 will reach its end of support. Following
              Microsoft's messaging, all Altair 2026 applications will no longer support Windows 10.
              Altair is providing this information to help our customers prepare and accommodate for
              this change. Altair 2026 will support the Windows 11 operating system, along with our
              other Linux-based operating systems. Please contact your local Altair support teams if
              you have any questions or concerns.
          - Red Hat Enterprise Linux 9.4 (64-bit)
          - Rocky Linux 9.4 (64-bit)
          - Memory
          - 16 GB of RAM (higher recommended)
          - 15 GB or more of free hard disk
          space
          - CPU/Graphics Hardware
          - OpenGL 3D graphics accelerator compatible with OpenGL 3.3 or higher
          - Vulkan 1.2 or higher
          - OpenCL 2.1 required
          - True color (24-bit) support
          - Install/update to most recent OpenGL patches/drivers
          - 1920x1080 screen resolution or higher for optimal user experience
          - 4 GB or higher dedicated RAM
          - CPU AVX2 support
          - Windows: Only dedicated AMD, Intel® Arc™, and NVIDIA GPUs are supported (integrated
            onboard Intel chipsets are not supported) with the following exceptions:
              - Inspire Rendering requires a dedicated NVIDIA GPU
                (AMD, Intel® Arc™, and integrated onboard Intel chipsets are not supported).
              - Inspire Fluids and Implicit Modeling work best on an
                NVIDIA GPU from the following list but will run on a CPU-only computer. For optimal
                performance, we recommend NVIDIA RTX graphics with at least 16 GB of RAM. Smaller
                amounts of RAM (4 GB or 8 GB) will work depending on model size and complexity.
                  - Supported NVIDIA GPU generations include Pascal, Volta, Turing, Ampere, Ada,
                    Hopper, or newer.
                  - Supported NVIDIA Graphics Drivers include version 460.89 or newer.
          - Linux: Only dedicated NVIDIA GPUs are supported (AMD, Intel® Arc™, and integrated
          - Video Recording
          - Any GPU can be used to record animated GIFs.
MP4 recordings require an NVIDIA Quadro
              P series (or RTX) or newer GPU with a driver version of 537.70 or higher.
    Additional Information on Driver Installations
      The NVIDIA Driver Update recommendation is to use the Custom
          installation option and select the Perform clean
          installation option to validate that there are no conflicts in
        DLL/drivers.
      The same should be done with AMD hardware and drivers as well using AMD’s custom uninstall
          tools.
          - Number of simultaneous jobs. Use of a workload management middleware like Altair PBS
            is highly recommended to ensure optimal and dedicated usage of the CPU resource.
Typical node configuration is based on dual CPU socket processors.
It is extremely important to populate all the memory banks on the motherboard.
In Hybrid mode, it is recommended to set a number of MPIs that is a multiple of the
              number of sockets and then set the number of OpenMP in a way that number of MPIs x
              number of OpenMP equals the number of physical cores.
          - Hyper-Threading (HT) may increase performance by around 10% on single node. In this
            case, the recommended setup is to run 2 OpenMP per MPI, with a number of MPIs that
            matches the total number of physical cores on the node. On multinode systems, it is
            better to not use HT.
      Platform Support (altair.com)
      Hardware Recommendations and Certifications
          (altair.com)
