3D curve: definition (structure)
Definition
The entity 3D curve is defined by:
- a name and a comment (optional)
- a quantity on the X axis (path, 3D grid, I/O parameter)
- a quantity on the Y axis (2D grid, I/O parameter)
- One or more quantities on the Z axis
Name
The user gives the name permitting the identification of the 3D curve during its creation.
A comment (optional) can be added to the name.
Types of 3D curves
The proposed 3D curves types and the characteristics necessary for their description are presented in the tables below.
| Type | Axe X | Axe Y | Axe Z |
| 3D curve (2D grid) | component 1 of the 2D grid | component 2 of the 2D grid | Local quantities |
| 3D curve (2 I/O parameters) |
1st I/O parameter |
2nd I/O parameter |
I/O parameters / sensors |
| 3D curve (path + I/O parameter) | path | I/O parameter | Local quantities |
