Results post-processing: software aspects
General points
Some general points to introduce the postprocessing menu:
Introduction to local quantities post-processing
Introduction to global quantities post-processing
What is a computation point?
Post processing on a computation step (Selector of scenario/of step)
Support
Available supports are:
Path
2D grid
3D grid
Cut plane
Computation axis of the torque
Graphic
Operating modes to represent spatial quantities on graphics :
Isovalues/Isolines
Arrows
Animation
Geometry reconstruction
Curve
Operating modes to represent spatial quantities on curves:
2D curve
3D curve
Import of curve
Superimposition of 2D curves
Computation
Operating modes for computations:
Quantity computation on points
Computation on physical entities
Evaluating iron losses à posteriori in magnetic cores
Evaluating iron losses à priori in magnetic cores
Evaluation of the demagnetization
Advanced
Operating modes for advanced computation:
I/O parameter (Input/Output)
Sensor
Predefined computations
Computation of integrales
Operation sensor
Current value of an I/O parameter
Data exchange
Operating modes for data exchange:
Export FMU block
Multipoint support
Export of N dimensions data table
Export of the nodes coordinates
Spatial quantity
Flowchart
Sequences (simplified) of commands:
Results post-processing: sequence of commands
Parametric:transient analysis: sequence of commands
Reading advice
For theoretical aspects (principles) of non parametric and non transient problem refer to chapter Results post-processing: principles .
For theoretical aspects (principles) of parametric and transient problem refer to chapter Parametric analysis principles .
For specific computations associated to magnetic applications refer to chapter
