3D curve: display / hide
Introduction
Once the 3D curve has been created, then it can be displayed on a sheet or hidden.
Display a 3D curve
To display a 3D curve:
Step Action
1 Select in the Data tree the desired 3D curve
2 Activate the contextual menu by click right on the selected 3D curve
3 In the contextual menu click on Display
→ The corresponding sheet is displayed
Note: it is possible to display several 3D curves, each sheet with its own tab that can be activated or not, which permits to hide a 3D curve without cancelling it.
Hide a 3D curve
To hide a 3D curve:
Step Action
3 In the contextual menu click on Hide
→ The corresponding sheet is hidden
Note: It is equally possible to hide one 3D curve, starting from the corresponding tab of its sheet by clicking on
