2D curve: environment (2D curve sheet)
Environment of a 2D curve
A 2D curve has got its own environment. The illustration below permits to identify each of the zones of the 2D curve sheet.
Zone of curve administration
The curves administration zone is subdivided into three tabs. The functions presented in each of the tabs are given in the table below.
| Proposition name | Tab | Function |
| (Representation / Properties / control panel/ Quantities) | Table |
| Table of values/ List of calculated values / ... | Values |
| Axes (scales) | Axes |
Display zone
The display zone is the zone reserved to the various graphs of the elementary curves.
Tool bar
The tool bar proposes the following tools:
- For value display (cursors)
- For framing (zoom, translation)
- For superposition of the elementary curves
