Motion Controllers
Unlike kinematics, you can add motion controllers to the geometry elements to allow objects to react to Particle-Geometry forces.
Forces acting on the geometry are included in the calculation of the geometries motion.
There is no contact detection between geometry elements. Sections pass through each
other when they come into contact. Motion control uses Geometry Mass to calculate
accelerations. The mass is automatically calculated in the Geometries Tree and can be
manually set. This should be representative of the real geometry mass and a non-zero
value.
Note: EDEM does not support
the following:
- Particle-Geometry interactions between particles outside the Dynamic Domain
- Geometries with force and torque motions
