Specify a Rotation
Rotations move the Geometry about a user-defined point with a specified angular speed and acceleration.
- In the Creator Tree, right-click an existing Geometry and then select Add Motion.
Select Linear Rotation Kinematic or
Sinusoidal Rotation Kinematic (used to model
oscillating motion).
Optionally, click the or the icons.
Rename the kinematic as appropriate and specify the following details:
For Specify Linear Rotation Kinematic Specification Start Time Specify the point in the simulation at which the motion will begin.
End Time Specify the point in the simulation at which the motion will end.
Select the Loop Every checkbox to enable the kinematic to be looped. For example, a kinematic with Start time of Xs and End time of Ys with Loop Every set to Zs would run from Xs to Ys then repeat again at (X+Z)s to (Y+Z)s and again at (X+2Z)s to (Y+2Z)s until the specified Until Time is reached. Until Time Specify the time until when the kinematic will be looped.
Initial Velocity Specify the speed of the section at the specified start time.
Acceleration Specify the acceleration. You can set the acceleration to 0.
Reference Space Select Local for the values to be based on the origin of the imported CAD Geometry, this will depend how the CAD file is drawn.
Select Global for the values to be based on the EDEM origin.
Select the Moves with Body checkbox to update the center as the section moves to ensure that the center of rotation remains in the same relative position to the Geometry section. Axis of Rotation Specify the X, Y, and Z values for the values for the Start and End point of the axis used for the rotation of the object. .
Select the Display Vector checkbox to display the vector used for the rotation to verify that the object will move in the correct direction. Point of Action Specify the point of action which is the center of rotation.
Sinusoidal Rotation Kinematic Specification Start Time Specify the point in the simulation at which the motion will begin.
Select the Loop Every checkbox to enable the kinematic to be looped. For example, a kinematic with start time of Xs and end time of Ys with Loop Every set to Zs would run from Xs to Ys then repeat again at (X+Z)s to (Y+Z)s and again at (X+2Z)s to (Y+2Z)s until the specified Until Time is reached. Until Time Specify the time until when the kinematic will be looped.
Frequency Specify the frequency of the oscillation.
Offset Specify the oscillation offset. For example, if you set two sections with identical oscillations offset by 180°, they will travel in opposite directions.
Displacement Magnitude Specify the amplitude of the oscillation in each direction.
Select the Moves with Body checkbox to update the center as the section moves to ensure that the center of rotation remains in the same relative position to the Geometry section. Axis of Rotation Specify the X, Y, and Z values for the Specify the X,Y and Z values for the Start and End point of the axis used for the rotation of the object.
