The Soils Starter Pack is included in the installation as a starter pack of soils
models.
These soils models represent a range of different soils from hard gravel to compressible
clay. You can run the simulation deck provided with each of the models to view the
characteristic described by the name of the model.
The simulation decks can be found in the following installation
directory:C:\Program Files\Altair\<EDEM version>\EDEM\examples\Soils
Starter Pack.
To use these material models in a simulation, copy them into the Material library (see
Material library) or modify the simulation deck provided.
Note: Contact models and their settings are defined in the
Physics section are not transferred to the Material library. However, you must
ensure that the behavior of the Material model is as expected.
