Test Descriptions
The following tests were performed - Untapped Bulk Density Test, Tapped Bulk Density Test, Static Repose Angle Test, and Compressibility Test.
Static Angle of Repose Test
0.05 kg of material was filled in a cylinder as per the untapped bulk density test. The sample material was then compressed under a pressure of 3 MPa (using the EDEM Coupling Interface) and the final material height recorded.
The amount of compression is calculated as: ‘Difference in sample height’/‘sample height before compression’, where the difference in sample height is the difference before and after compression.
The Compressibility index and Hausner ratio are calculated as: 100 x (tapped density – untapped density)/tapped density’ and ‘tapped density’/‘untapped density’ respectively.
Estimating Run Times
| Compressibility Ratio | Time step(s) | Cases |
| 0.1 | 8.00E-07 | 1, 4, 7 |
| 0.5 | 6.00E-07 | 2, 5, 8 |
| 0.9 | 3.00E-07 | 3, 6, 9 |
However. investigations into the Time Step suggested that the Compression tests and Angle of Repose tests were unaffected by running at higher Time Steps. A value of 2e-6 s was used for the Angle of Repose tests and 5e-6 s for the Tapped Bulk Density tests.
| Time step(s) | Simulation run time (s) | Time per iteration per particle (microseconds) | Number of Particles | Estimated Run Time (days) |
| 2.00E-06 | 1 | 1.2 | 1000000 | 6.9 |
| 2.00E-06 | 1 | 1 | 1000000 | 5.8 |
| 2.00E-06 | 1 | 0.8 | 1000000 | 4.6 |
| 2.00E-06 | 1 | 0.6 | 1000000 | 3.5 |
| 2.00E-06 | 1 | 0.4 | 1000000 | 2.3 |
| 2.00E-06 | 1 | 0.2 | 1000000 | 1.2 |
Number of Iterations = EDEM run time/EDEM Time Step.
Seconds Per Iteration = elapsed real time/number of iterations.
Time Per Iteration per particle = Seconds Per Iteration/Number of particles.
The time per iteration per particle is measured from the relevant hardware setup. First, set up a simulation that takes around 1000 iterations. Then use a stopwatch to measure how long the elapsed real time for the simulation is and use this to calculate time per iteration per particle.
This is typically in the range of 1 microsecond for 8-16 processors. Different values will be found depending on how many spheres are used to make up a particle shape and the type of contact model used.
According to the table, the time per iteration ranges from 1.2 which is high-end CPU’s and 0.2 which would be for a high-end GPU.
