Thermal diagram
Introduction
Synchronous machines with permanent magnets
The following picture gives an example of a simple thermal circuit, including the main resistances corresponding to the default synchronous machine with permanent magnets.
Reluctance synchronous machines
The following picture gives an example of a simple thermal circuit, including the main resistances corresponding to the default reluctance synchronous machine.
Wound field synchronous machines – Inner salient poles
The following picture gives an example of a simple thermal circuit, including the main resistances corresponding to the default wound field synchronous machine with inner salient poles.
Induction machine with squirrel cage
The following picture gives an example of a simple thermal circuit, including the main resistances corresponding to the default induction machine with a squirrel cage.
