Slot
Overview
In Motor Factory – Design area, the environment “Slot” allows to design the shape and the dimensions of the machine slots.
For Inner Rotor machines, three sections are available: Design, Lamination and Skew.
For Outer Rotor machines, two sections are available: Design and Skew.
| 1 | Selection of the Slot panel (Click on the icon Slot). Several
sections allow defining all characteristics that deal with the
Slot: Design, Lamination and Skew. Note: Lamination is available for inner rotor topology but not
for outer rotor topology.
| 2 | The design tab gives access to the section dedicated to the
design of the slot. Note: By default, the
section Design is selected. |
| 2.1 | Selection of the shape and settings of the user inputs dedicated to the design of the slot. |
| 3 | The lamination tab gives the tools to define the shape of the
lamination. Note: This section is only
available for inner rotor topology machines. |
| 4 | Skew tab gives the tools to define the slot skew topology. |
