Lamination
Type of lamination
The tools available in the lamination tab allow us to define the outer shape of the lamination.
Two choices are available for defining lamination topology: Circular or Square.
Note: Lamination is available for inner rotor topology but not for outer rotor topology.
Circular shape lamination
By default, the lamination is circular. The outer diameter of the lamination is defined in the structural data of the topology in the specification of the machine.
Table 1. Slot – Lamination - Design area – Circular type lamination
1 Default setting: Lamination type is « Circular ».
Square shape lamination
Table 2. Slot – Lamination - Design area – Square type lamination
1 Selection of a “Square” type lamination.
  1. Main type of square shape lamination
    Table 3. Main type of square shape lamination
    Square shape lamination with right corner Square shape lamination with chamfer corner
    Setting of the length corresponding to a 45° chamfer
    Table 4. Main type of square shape lamination
    Square shape lamination with fillet corner - Setting of the lamination fillet radius
  2. Definition of the slot angular shift
    With square shape lamination, it is possible to set a slot angular shift. It is advised to keep an angular shift lower than one slot pitch.
    This parameter allows adjusting the outer dimension () between the outer border of the lamination and the bottom part of the slots. For more details see the illustrations below.
Figure 1. Square shape lamination Definition of the slot angular shift = 15.0 i.e. half the value of the slot pitch.
Figure 2. Square shape lamination Definition of the slot angular shift = 0 i.e. original default value.
