Slot
Slot conduction mode
The thermal exchanges from the conductors to the stator core are complex phenomena for which FluxMotor embeds a dedicated model.
This panel allows choosing the conduction model from the conductors to the stator core.
By default, a FluxMotor model is proposed. This model uses the slot
fill factor, the conductor shape, and the conductivities of the materials inside the
slot to compute two equivalent conductivities:
- The radial and orthoradial conductivity of the winding, used to compute thermal exchanges from the winding to the stator core.
- The axial conductivity of the winding used to compute thermal exchanges from the in-slot winding to the end windings.
Two ways are proposed to define the slot conduction: an automatic and a user one.
| 1 | Auto mode: This mode allows us to set the slot conduction automatically by internal process. |
| 2 | User mode: This mode allows us to set the slot conduction manually. |
User mode
The user mode allows to set the user slot conductivities manually.
In user mode, the following inputs must be set:
The default value is 1.5 W/(K.m).
- The axial conductivity of the winding used to compute thermal exchanges from the in-slot winding to the end windings. The default value is 200 W/(K.m).
