Altair® Panopticon
Creating a Data Source
Panopticon Streams supports creation of data sources that can be used as inputs or outputs in the application model.
1.     On the Data Sources tab:
·         click  on the toolbar, or
·         right-click on a folder or subfolder and select New Data Source
The New Data Source dialog displays.
2.     Enter the Name of the data source and click .
The Data Source tab displays with the following sections:
Section/Pane
Data Source Name
Name of the data source. Click the  button to go back to the Data Sources listing page.
Connector drop-down list
Includes the input data sources and output connectors.
Save
Saves the changes made on the Data Sources tab.
3.     Enter the Name of the data source. This should be unique and should only contain letters (a to Z), numbers (0 to 9), and underscores.
4.     Click  or press Enter to apply the name.
5.     Select any of the following:
·         output connectors
¨        Email
¨        InfluxDB
¨        JDBC Databases
¨        Apache Kafka
¨        Kx kdb+
¨        MQTT
¨        Rest
¨        Text
·         Input data sources
¨        ActiveMQ
¨        Amazon Kinesis - Data Streams
¨        AMPS
¨        Elasticsearch 5.x
¨        Elasticsearch 6.x
¨        Elasticsearch 7.x
¨        Google Cloud Pub/Sub
¨        InfluxDB
¨        JDBC Database
¨        JDBC Database - Streaming
¨        JSON
¨        Apache Kafka
¨        Kx kdb+
¨        Kx kdb+ Tick
¨        ksqlDB
¨        ksqlDB - Streaming
¨        Livy Spark
¨        MongoDB
¨        MQTT
¨        MS Excel
¨        OneTick
¨        OneTick CEP
¨        OneTick Cloud
¨        Python
¨        RabbitMQ
¨        Rserve
¨        Solace
¨        Splunk
¨        Stream Simulator
¨        StreamBase 7.1
¨        StreamBase LiveView
¨        Text
¨        WebSocket
¨        XML
The tab page changes depending on the selected connector.
