Altair® Panopticon
Creating Stream Simulator Input Data Source
The Stream Simulator connector is very similar to the Text connector with the addition of the time windowing of message queue connectors.
Creating the Stream Simulator input data source includes setting for how fast and how many messages are pushed through in each batch.
1.     In the New Data Source page, select Input > Stream Simulator in the Connector drop-down list.
2.     Select the Text File Source:
·         Text
Enter the text block to be parsed.
·         File
You can either:
¨        Upload a data source snapshot by clicking Upload File  then Browse  to browse to the file source.
After selecting the file, it is displayed with the timestamp of the snapshot.
To change the data source, click  then Browse  to browse to a new version of the file.
¨        Link to a data source file by clicking Link to File  and entering a Text File Path.
Ensure that in a cluster, you need to use a a shared path, or put it on every node and use a path that resolves on every node. You can update its contents whenever you want.
·         WebURL
The dialog changes slightly to allow specification of the following:
Property
Path
The location of the message broker.
Proxy Server URI
The HTTP Proxy setting that will allow the Stream Simulator connector to reach the endpoint
User Id
The user Id that will be used to connect to Stream Simulator.
Password
The password that will be used to connect to Stream Simulator.
Check the Show Characters box to display the entered characters.
Request Body
The Request Body for the HTTP POST.
Timeout
The length of time to wait for the server response (10 to 300). Default is 10.
The standard settings controlling how the text file is parsed, is listed.
These include:
Property
Skip First N Rows
Specifies the number of rows that will be skipped.
Data Type Discovery
Specifies how many rows from the text file should be used when automatically determining the data types of the resulting columns.
Decimal Separator
Select either the period (.) or comma (,) as the decimal separator.
Text Qualifier
Specifies if fields are enclosed by text qualifiers, and if present to ignore any column delimiters within these text qualifiers.
Column Delimiter
Specifies the column delimiter to be used when parsing the text file.
First Row Headings
Determines if the first row should specify the retrieved column headings, and not be used in data discovery.
3.     Click  to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
4.     You can also opt to load or save a copy of the column definition.
5.     You can opt to click . A new column entry displays. Enter or select the following properties:
Property
Name
Column Index
The column index controls the position of a column. Must be >= 0.
Date Format
Filter
Defined parameters that can be used as filter.
Enabled
Determines whether the message should be processed.
To delete a column, check its  or all the column entries, check the topmost , then click .
6.     Select the Simulation Type:
·         Record
Sends the number of records for each interval of time. By default, records are sent in the same order of the source.
This simulation type allows the specification of the following:
¨        Sort Order
When you select the Use file sort order, it will use the default sorting order of the file.
When you either select Ascending or Descending as the Sort Order, this enables the Sorted by Column drop down list.
Select the column that will be used for the sorting.
¨        Update Set Size
The number of records set to be updated during simulate/playback.
¨        Start Up Set Size
The number of records set to be published initially (on start-up).
¨        Update Interval (ms)
The update interval period for the record-based playback. Default is 1000 (ms).
·         Time
Simulates records as they occur in real-time.
¨        Playback Column
The playback column which is a Date/Time type.
¨        Playback Speed
A multiplier which to either speed up or slow down the playback. Default is 1.
o    If 0 < value < 1 slow down
o    If value = 1 records will be published as they occur
o    if value > 1 speed up
   NOTE
For time-based simulation, if the Date/Time column have improper dates, it will fail and stop.
7.     Select the ID Column.
This defines the column that uniquely identifies a row in the returned stream, and is used for processing inserts, updates and deletes.
By default, only the latest data will be loaded into memory. A streaming time series window can be generated by creating a compound key with the Id Column, plus a separately specified Time ID column. This Time ID column can be from the source dataset, or alternatively automatically generated.
If the Time Id column is selected, then a scrolling time window can be specified. As new data arrives from the subscription new time slices will automatically be added, and old ones will be deleted.
For Automatic Time Id, define the Time Id Column Name.
8.     Modify the Real-time Limit to vary the data throttling. This defaults to 1000 milliseconds.
9.     Check the Loop box to enable looping through the file.
10.   Check the Reset Data on Reconnect box to flush out the stale data and reload data after reconnection.
11.   Click . The new data source is added in the Data Sources list.
